shock tension
Old Jan 8, 2005 | 12:36 PM
FFCHADBO's Avatar
Default shock tension
What is the easiest way to increase the tension on the DS shocks?
Looking for a little help. Thanks[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 8, 2005 | 01:30 PM
ds650ratrider's Avatar
Are you trying to make the bikes riding stance higher or the suspension firmer?
Old Jan 8, 2005 | 08:45 PM
TheChosenOne's Avatar
Rear has a compression rebound setting, as well as preload on the spring. Fronts just have preload. Which are you trying to adjust?
Old Jan 12, 2005 | 02:07 PM
FFCHADBO's Avatar
Please forgive my lacvk of knoeledge.
I'm looking at the spring/coil and it looks as if you can increase the tension on the spring/coil?
Is that possible?
Thanks
Old Jan 12, 2005 | 04:17 PM
blue250r's Avatar
Ok if you mean how much wieght it wil take to commpress the shock by a given amount, then yes you can on the rear you will see threads on the upper part of the shock there are two nuts with tabs sticking out the upper nut is just there as a lock/jam nut the lower one will increase / decrease tension on the spring depending on which way you screw it.
the front shocks are similar but the adjusters at the bottom and they have a clip instead of a lock nut.
How heavy are you and why do you want to adjust it, the info i gave is for a 2004 model im not sure about the older ones may have different shocks.
if you tell us why you feel you need to adjust then we can give you better advice on what set up to go with
Old Jan 12, 2005 | 06:46 PM
FFCHADBO's Avatar
I wanted to increase the tension because I'm 6'9' and 300 pounds not your average ATV rider.
Thanks for the help
Old Jan 12, 2005 | 07:15 PM
blue250r's Avatar
Ok i see
Do you have a manual for the bike you need to set up the sag it wil tell you how if not i will scan the page and e mail it to you
Old Jan 12, 2005 | 07:58 PM
omahapredator's Avatar
the rear shock should have 30% of total travel as sag ( ride height ).....the fronts are same but 20% instead of 30..kind of a universal rule of thumb..now if your dragracing ofcourse you want to slam it as low as possible...
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
raman8tor
Sep 20, 2015 07:35 AM
bigred20653
Sep 19, 2015 02:11 PM
bvolks
Sep 13, 2015 12:57 PM
