snowmobile primary clutch
Old Jan 9, 2005 | 08:54 AM
corvetteguy's Avatar
Default snowmobile primary clutch
I know I am off topic but I am sure you
guys can provide a quick answer.
I have a late 70's TNT 440cc. I need to
remove the primary clutch while it is in
the sled. The outter portion backs up
when the center bolt is removed but the
inner sleeve does not pull off from the
motor. Is a special puller needed?
Or is there a way to improvise a way to
pull the tapered shaft off the motor.
Thanks
Old Jan 9, 2005 | 06:11 PM
loveotride123456789's Avatar
its threded on there u need to turn it put a pice of mealt in the hole in the end and turn it left if that dose not work use a munkey wrech then file the end down when u r done so it gose back on
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
