snowmobile primary clutch
I know I am off topic but I am sure you
guys can provide a quick answer.
I have a late 70's TNT 440cc. I need to
remove the primary clutch while it is in
the sled. The outter portion backs up
when the center bolt is removed but the
inner sleeve does not pull off from the
motor. Is a special puller needed?
Or is there a way to improvise a way to
pull the tapered shaft off the motor.
Thanks
Thanks
Steeldon
09-09-2015 09:38 AM
