off subject ski-doo elan 250
Old Jan 9, 2005 | 10:03 PM
BIGREDRIDER2233's Avatar
Default off subject ski-doo elan 250
I no this is off subject but i don't no anyother website where i could get info on snowmobiles. I was wondering if u guys know how to adjust a carb on an elan. MY old 71 250 runs good but i can't go full throttle on it and the old man says its in the jets on the side of the carb and does any one know how many turns they should be in on it. Thanx for the off subject help Or do u no a website i could aske questions about a snowmobiel
Old Jan 14, 2005 | 03:22 PM
barrister1's Avatar
Go to the forums at www.snowest.com. Tons of knowledgable folks there. Should be a good place to start.
Old Feb 11, 2005 | 04:14 AM
Fr33ze's Avatar
Turn both in all the way, be carfull not to be to tight, then both come out 1 and a quarter turns for a start point. Then fire up the sled and fine tune it with the track up off the ground. One screw adjusts the low speed jet, has an "L" above it (whitch seems like it was already good), and the other is the high speed jet, has an "H" above it.
If the high speed jet wont change the way it runs, you have to tear down the carb, soke it in carb cleaner, blow out the holes that the adjuster screws go into with a compresser, dont mix the screws up, new carb kit (15 bucks) and you should be up and going.
Hope this helps ya[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 19, 2005 | 02:21 PM
Thanx but now its been fowelling plugs so iunno what to do bout that.
Old Feb 19, 2005 | 02:32 PM
Fr33ze's Avatar
Now its eather too rich(oil), or the ignition system is acting up...
Coils bight be going bad, colder/hotter plugs might help, check magnito for rust, points & condencers... mostly cheap teedeius work.
And lastly, old ski-doo's have issues with there oil injection pump. They mount it on the recoil, and I've found that if snow gets into the oil resivoir, then ice forms in the pump, and or small oil lines, and clogs. Clean it regularly, or mix your gas, I've had to replace a few piston/jug sets form a failed oil injector.
Old Feb 21, 2005 | 11:53 AM
I can ride it fine and go for hours but if i let it sit ideling the plug will get soked and i can't take off it will just idle with the throttle open until i clean teh plug. So i have no clue watssup thanx alex;
Old Feb 21, 2005 | 02:05 PM
Fr33ze's Avatar
Still sounds like the "L" screw is out to far. The screws are very sensitive, a 1/32 of a turn does a lot.
I recall a sled that I had to screw the "L" in ALL the way to get it to run right... The carb was very warn out.
Getta COMPLETE carb kit, and rebuild with NEW pieces. Sometimes using the old gaskets, even if the look good, can cause greef.
If you cant dial in the carb, you might want to find another Tillitson HR carb to swap with, to see if it realy is the carb giving all the problems.
ripperray
Oct 10, 2023 02:42 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Elkaholic
Sep 6, 2015 02:44 PM
cman
Dec 20, 2000 08:03 PM
mikeames
Oct 22, 2000 10:13 PM
