bouncy ride
Old Jan 18, 2005 | 04:35 AM
htloi's Avatar
Default bouncy ride
my sons 50 cc mini doesnt handle bumps very well. its a alpha sports 50 cc mini. are there any aftermarket shocks to make it better? he mostly trail rides. thanks
Old Jan 18, 2005 | 10:45 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Default bouncy ride
If it's the full-size mini, you can get works or elka.
Call Billy at WRH Racing.
WRH
Old Jan 18, 2005 | 01:07 PM
spike99's Avatar
Default bouncy ride
htloi,
Works, Elks, PEP and other shock specialist companies may be able to help. When ordering shocks from them, you need the rider weight and your specific riding conditions, so they tune the shocks behavier. Thus, getting the best performance for your unique conditions. Because of this, these shocks are very expensive. I've heard that Works Shocks are the least expensive.
As a suggestion, you could take the measurements of your current shock(s) and compare against other 50cc and 90cc brands. Sometimes, you may get lucky and find another shock that not only bolts directly on, but is better then your current 50cc shock. More lbs and more movement. Stock shocks from a different brand are much less expensive then high performance shocks.
Hope this helps too.
Old Jan 18, 2005 | 08:35 PM
Bluetickracing's Avatar
Default bouncy ride
The elka's are real pricy. I ordered a set of works for my son's 70 Arctic Cat. They were $620 delivered to the door. They will take 2 to 4 weeks to make.
Old Jan 19, 2005 | 03:32 PM
htloi's Avatar
Default bouncy ride
it is not a full size mini
Old Jan 22, 2005 | 08:58 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Default bouncy ride
I know this sounds condsending, but did you check the air pressure in the tires? Most mini's recommend less that 5 lbs of pressure... The tires really have more to do with suspension on these than the shocks....
Old Jan 24, 2005 | 01:41 AM
quadduck's Avatar
Default bouncy ride
Most minis have bad suspension and its probably not worth upgrading a 50 unless they are going to be raced.
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
