BRUIN TRANSMISSION
Old Jan 19, 2005 | 01:58 AM
DONTHATE's Avatar
Default BRUIN TRANSMISSION
I HAVE A 2004 BRUIN THAT I DROVE IN THE MUD, NOW WANT GO PASS SECOND GEAR .I CAN FULL THROTTLE THE MOTOR AND THE BIKE ONLY GOES ABOUT 20 MPH. I'VE DRAIN ALL THE PLUGS .THE BIKE HAS SAT AND DRYED FOR ABOUT A WEEK.WHAT COULD IT BE. ANY IDEAS. THANKS
Old Jan 19, 2005 | 09:34 AM
Kodiakmudslinger's Avatar
Sounds like you're gonna have to pull the cover off, and clean out the springs/counterweights whatnot for your clutch/gear/pulley assy.
I've heard guys have the same problem before, even after draining/cleaning/hosing out/whatnot, and drying it, and that's what they always have to resort to.
Once you get mud in the springs/counterweights and it dries, you pretty much have no choice but to take it all apart, clean them up and re-lube them. Depending on the type of spoo you get in there, it doesn't always take a whole lot either. Just gum up the moving parts, and you're done. The belt can't run like it's supposed to, and will slip, or not move down for higher gearing.
After a good cleaning/lube, the top end comes back and they work fine. A good manual will walk you through it.
Good luck.
Old Jan 19, 2005 | 08:18 PM
Here's a bit more detailed info on it.
This thread is for a a Griz, but it's the same process for the Kodiak and Bruin.
http://forums.atvconnection.com/mess...did/430965.cfm
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
