Problem with differential
Old Jan 21, 2005 | 07:46 PM
Rusroc's Avatar
Default Problem with differential
I recently broke a cv joint. I replaced both front axles with Gorilla Axles. When I finished the front end, I tried to run the bike on the stand, but the rear tires would not turn. I checked the brakes and that was not the problem. I feel that the differential is locked up. How can I get iy loose again?
Old Jan 22, 2005 | 02:13 AM
elkbow's Avatar
which machine are you talking about? what was different in the installation vs the re-installation...
when you broke the CV joint, where did it break, right at the joint?
Old Jan 22, 2005 | 10:47 AM
Rusroc's Avatar
Sorry about that. I have a 2004 Sportsman 600 4x4. I broke the right front CV joint. I think that the problem could be a rear bearing that has locked up.
Old Jan 22, 2005 | 02:55 PM
Rusroc's Avatar
Hey guys it was just the left rear bearing that was locked up. I replaced the both stock rear bearings with pivotwork bearings. Problem solved.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
