What pred would you choose?
Old Jan 22, 2005 | 11:48 PM
Pigpen7684's Avatar
Default What pred would you choose?
Would you rather want a 2005 STD Predator or a 2005 TLD Predator?
Old Jan 23, 2005 | 12:08 AM
poopy's Avatar
i think the TLD has better suspension and geared different for more low end. so i would probably pick that one since i dont usually use top speed that much.
Old Jan 23, 2005 | 01:24 AM
RAJ's Avatar
RAJ
The std would have more low end...the tld is geared higher. I would say go out and ride both, and see what you think.
Old Jan 23, 2005 | 01:46 AM
MnFriesen's Avatar
is the tld geared higher?? I thought that second and third were geared to shift out quicker and then the rest of the gears were the same...well it ends up being the same top speed
Old Jan 23, 2005 | 02:00 AM
RAJ's Avatar
RAJ
They changed 2-4 on the tld. 1 & 5 are the same.
Gear Ratios
Std.----------------------tld.
1. 2.4-----------------------2.4
2. 1.6-----------------------1.9
3. 1.3-----------------------1.5
4. 1.1-----------------------1.2
5. 0.9-----------------------.09
Old Jan 24, 2005 | 01:14 AM
Pigpen7684's Avatar
I'm confused now RAJ I thought the TLD was more low end power and accelerated better/faster then the STD.
Old Jan 24, 2005 | 02:56 AM
RAJ's Avatar
RAJ
The tld is geared higher, 2-4 and 1 & 5 are the same as the std. Ok looks like the tld 2-4 would be like putting a 15 tooth front sprocket on.
Old Jan 24, 2005 | 03:34 AM
Polaris500HO4x4's Avatar
tld ...isnt it a little more expensive tho
Old Jan 24, 2005 | 11:01 AM
propolaris's Avatar
The tld is geared lower than the the std predator except for 5th gear, they have the same fifth gear. I perfer the std even the mags like the std. tranny better but they like the suspension and tires on the tld.
Old Jan 24, 2005 | 12:03 PM
RAJ's Avatar
RAJ
Ok I was thinking wrong for some reason. You are right it is geared lower then the Std.
BYC
Sep 25, 2015 02:10 PM
carid
Sep 14, 2015 03:40 PM
JakeXBL
Sep 5, 2015 01:08 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
