Removel of handle bar cover on my 04 300ex
Old Jan 23, 2005 | 01:34 AM
exbob88's Avatar
Default Removel of handle bar cover on my 04 300ex
hey guys ive got a 2004 300ex and i want to get rid of the handle bar cover but i dont know how and what do with the ignition and also what do think are the best tires foe the 300ex thanks.
Old Jan 23, 2005 | 02:29 AM
KingRacing's Avatar
The ignition wire is in your headlight.. Its just a pull off and its like a 3 min job. Tires id go with Razrs or dirtdevils.
Old Jan 23, 2005 | 11:44 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
As for tires, ITP Holeshot XC's, on ITP T9 rims. It will make the bike several inches wider, for some nice added stability. Way nicer than those stock balooners!
It has been a long time since I owned a 300, so I am trying to remember. The key is on the handlebar cover, right??? I think I relocated the key by just drilled a 1" hole down on the side somewhere. The bike looked a little unfinished without the cover, so I bought a cover for a 250X (fits behind the light, and covers the handlebar mount), and it filled in the open spot behind the lights. Looks lots better. You might be out of luck if your bike is yellow though (the old 250X was red).
Old Jan 23, 2005 | 03:23 PM
LocknLoad's Avatar
There are 2 round circles in the middle of your cover, pry them out with a small screwdriver, this will give you access to the mounting screws.
If you want you can relocate your key switch to your headlight case. I relocated the reverse light behind the neutral light, then drilled a 1" hole where the reverse light was. There is not enough room in the middle of the headlight cover for the key switch, it has to be to one side or the other.
Or you can relocate it down on the side plastic below the handlebars. again drill a 1" hole, the switch will pop right in.
Now that you have bare handle bars, put on a crossbar pad like this. they fasten on with velcro around the bars. Good safty item and look good.
http://www.rockymountainatv.com/Prod...v?pid=00037258
Old Jan 23, 2005 | 04:19 PM
exbob88's Avatar
hey guys thanks for looking at the theard and for giving your response but how dose the ignition com out
thanks
Old Jan 23, 2005 | 05:37 PM
KingRacing's Avatar
i told you how it comes out. Take your headlight cover off and unsnap the ignition wire off of the other wire. then take the handlebar cover off and re snap it inside the headlight.
Old Jan 23, 2005 | 06:04 PM
Trevor's Avatar
Can someone show some pics of this done using the stock bars and where you relocated ignition and lights! I have also thought of doing this!
ReconBayou
Oct 16, 2019 02:24 AM
badgerboy1
Sep 26, 2017 06:11 PM
jbrewster94
Sep 23, 2015 04:16 PM
carid
Sep 14, 2015 03:40 PM
Lou Domenech
Sep 11, 2015 06:35 PM
