2002 SP500 neutral light and starter problem
Old Jan 23, 2005 | 11:06 PM
1Bullmoose's Avatar
Default 2002 SP500 neutral light and starter problem
I'm having an electrical problem with my 2002 Sportsman 500. The neutral indicator light and electric starter do not function when the quad is shifted into neutral. The starter works normally when quad is shifted into high or low range. I checked all the wiring and connections but found nothing.
Wiring diagrams are greek to me and Polaris has a strange way of grounding things together back in the pod rather than to the frame. Any help would be appreciated.
Thanks
Old Jan 23, 2005 | 11:37 PM
ghost69's Avatar
sounds like the switch on the transmission is bad. i beleive its the rear switch. ran into this problem at the shop before.
Old Jan 26, 2005 | 05:17 PM
1Bullmoose's Avatar
Thanks Ghost.
I pulled the switch off and checked continuity in the 3 positions. It seems to operate correctly as drawn on the wiring diagram. Any other ideas?
To clarify, here's the problem:
High or low range - everything works
Neutral or reverse - no starter, no indicator light, no speedo light
Anybody else had this problem?
Thanks
Old Jan 26, 2005 | 11:09 PM
lusty's Avatar
I have a similar problem. When I shift into reverse the engine stalls. When in neutral the neutral light gets really bright and the headlights go dim and bright and repeats. Then I can't start it again till I move the headlight and or starter switch back and forth. My quad is an Explorer, 2001
Old Jan 28, 2005 | 02:28 PM
1Bullmoose's Avatar
Must be some "Wizards of Wiring" out there.
My local Polaris dealer is just awful and the next closest is a 2 hour drive away, so I would really appreciate any suggestions.
Thanks
Old Jan 30, 2005 | 09:09 PM
lusty's Avatar
Hey 1Bullmoose, I see we are fellow Albertans. Where abouts are you from? I live in Sylvan Lake. This electrical problem ran my battery down. I heard from someone that my problem could be the switch in the transmissiion. They had similar problems.
Old Jan 30, 2005 | 09:21 PM
2manytoys's Avatar
Lusty,
The problem with yours is the reverse override switch. You need that whole assembly. My brother inlaws sp600 did the same exact thing. Me being a mechanis checked all the wires and switches in the whole machine. I came to the conclusion that the switch assembly was bad. He then replace it and it has worked fine ever since.
One thing you can try is hold the switch in and then put it in reverse. See if it dies or not.
Old Feb 1, 2005 | 01:44 AM
lusty's Avatar
You are right about holding the button down while in reverse, it does not die on me. I discovered this soon after the problem. I didn't think it was the switch. when you say whole assembly, what exactly do you mean?
Old Feb 1, 2005 | 11:03 PM
lusty's Avatar
Also, can a guy bi-pass the switch? lusty
Old Feb 1, 2005 | 11:30 PM
dontgetbehindme's Avatar
I don't know if you do this ,but it sure makes a big differance,WD-40 all mechanical and electrical parts after a ride or wash, and every so often unplug connectors and spray them as well. I won't say this will cure all problems but I know first hand it will reduce them.
ripperray
Oct 10, 2023 02:42 AM
Mkp
Mar 28, 2020 03:50 AM
AtvManiac78
Jul 11, 2015 03:20 AM
jayking232003
Jun 9, 2015 02:54 PM
ds-newbe
Jun 3, 2015 05:40 PM
