05 Brute Force 650
Old Jan 27, 2005 | 11:36 PM
BruteForce650's Avatar
Default 05 Brute Force 650
I just put a plow and winch on my 05 BF 650 and the winch had to get hooked up to the ignition switch, I taped into a red wire under the seat and now the 4 wheel drive works when it wants to and the reverse indicator light works when it wants to. Anyone have any idea what i did? It seems like a loose wire but i have no clue.
Old Jan 28, 2005 | 12:19 AM
brutebadger's Avatar
Sorry, I can't tell you what you did but I want to know what kind of winch you put on your Brute? If it is a Warn, where did you get the mount?
Old Jan 28, 2005 | 02:40 AM
rivermud's Avatar
Is the brute 650 a similar setup to the prairie as far as the winch mounting. Might want to check. The bf 650 is probably to new to have the listing but others might work with it. Sorry cant help with the wires
Old Jan 28, 2005 | 03:32 AM
The front end of the BF is different than that of the Prairies. My dealer was saying that a mount won't be out til spring, but I don't want to wait that long. I have also heard that Parts Unlimited will have them available as soon as FEB 4th. Now I hear that somebody already has one mounted. I don't know, maybe it's not a Warn. That's why I am asking. I do know that Ramsey has a mount for the BF650 though. I'm just confused now as far as this is concerned.
Old Jan 29, 2005 | 05:10 PM
I just went to my local Kawasaki dealer and got the winch and mounting bracket, the winch is made by Warn. The dealer i got it from is in NY if interested i can get you their number
Old Jan 29, 2005 | 06:27 PM
Nightryder888's Avatar
the wire that hooks to the ignition needs to be spliced into the brown wire coming off of the switch
Old Jan 29, 2005 | 10:45 PM
kawiyowee's Avatar
Thanx
Old Feb 3, 2005 | 09:16 PM
widebodyginster's Avatar
the winch he has is a quadboss 1700 lbs...its right on quadboss.com they prolly have a list of dealer's
Old Feb 3, 2005 | 10:08 PM
Yea what he said
Old Mar 17, 2005 | 12:06 PM
rcgolfman's Avatar
E-WINCH.COM HAS A WINCH MOUNT THAT WILL FIT THE RAMSEY AND THE WARN FOR THE 05 BRUTE FORCE 650. YOU ALSO HAVE TO TAP INTO THE BROWN WIRE ON THE IGNITION
