Gear lube...gl-5 a replacement for gl-4?
Old Jan 29, 2005 | 01:17 AM
hondabuster's Avatar
Default Gear lube...gl-5 a replacement for gl-4?
Specs on the kodiak call out 80 wieght GL-4 gear lube. Went to the auto parts store and only found GL-5 lube. From what I can tell, the only difference is more sulfur, in the GL5. Anyone know if GL5 is ok to use as a replacement for GL4?
Old Feb 5, 2005 | 09:01 PM
stuck's Avatar
Both of these lubricants are used in many different Automotive applications such as manual transmissions and differentials. I used to work for Pennzoil and from what I remember you can not deviate. If it calls for
GL-4 I wouldn't use GL-5.
Old Feb 6, 2005 | 04:49 PM
Thats what I was thinking. I found some amsoil 75w-90, rated for gl3 to gl5. Should work out ok, and have the added benifit of flowing easier in cold weather.
Thanks
Old May 12, 2005 | 08:03 PM
BigdogonaBigBear's Avatar
if you look in your owners manual it tells you that gl 4 is a minimum rating and that its ok to use gl 4, 5, or 6.
Old May 12, 2005 | 08:16 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
"The most common gear lube is 80-W90 weight oil. The GL designations represent characteristics of the oil. Some are designed for smoother shifting, some for a wider range of operating temperatures and others for improved bearing lubrication. GL5 is used mostly in limited slip differentials and can be used in place of GL4, but NOT vice versa". http://autorepair.about.com/library/faqs/bl904.htm
I use Mobil 1 75W90, which is GL4/GL5. Thinking of switching to Maxima or Redline though.
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
