Question on rear drum brake
Old Jan 31, 2005 | 01:19 PM
antman19's Avatar
Default Question on rear drum brake
I have a 2001 Predator 90. How do I tear apart the rear drum brake ?
Old Jan 31, 2005 | 01:43 PM
spike99's Avatar
On my '03 Pred-90, here's how it worked for me....
1 - Losen the left wheel bolts.
2 - Install auto jack under the rear hub assumble. Middle of hub.
3 - Remove the left rear tire.
4 - Remove the rubber cap - kinda twists and pulls off.
5 - Remove cotter pin in the axle's large nut.
6 - Unscre the large nut - standard thread direction.
7 - Pull the rear hub off.
8 - Slide the axle cylinder spacer tubes off.
9 - Using your hands, pull the brake drum off. If it's stuck, use a rubber hammer and lightly tap the outside of the drum. Don't tap too hard cause it may break the drum. If it still doesn't come off, spray WD-40 where the axle groves contacts with the brake drum. Let sit for 30 minutes, then try agian.
For a picture of where the axle groves sometimes rust to the brake drum, surf: - Press Here -
Hope this helps...
Old Jan 31, 2005 | 06:33 PM
spike99's Avatar
If you are planning on replacing the brake pads on your 2003+ Predator (or other 2001 Polaris mini), you may want to get slotted brake pads. For pictures, surf:
My original / old pad: - Press Here -
My replacement / new pad: - Press Here -
Many say the slotted pads are much better...
Hope this helps as well....
Old Feb 2, 2005 | 09:04 AM
antman19's Avatar
Thanks for the reply. Everything came apart with ease. Pretty simple but its nice to be able to ask before you start taking things apart on your own.
toonces
Oct 16, 2019 12:11 PM
greg74
Sep 10, 2019 03:03 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
