raptor neutral light?
Old Feb 2, 2005 | 03:21 AM
deathmetal's Avatar
Default raptor neutral light?
here's two questions about the neutral light on a raptor. first, my buddy was riding along with us today on the raptor and all of a sudden, the neutral light starts blinking along with the headlights. anyone know why? im wondering if its a sign just like the reverse light blinking for over revving? cant seem to find it anywhere on here either. also, this is on a totally different raptor. the raptor was rebuilt with a new tranny, yet the neutral light stays on constantly even throughout shifting in every gear, what would cause this?
Old Feb 3, 2005 | 01:23 AM
deathmetal's Avatar
yeah, nobody? O_o
Old Feb 3, 2005 | 08:04 AM
Turbo33's Avatar
sounds loke a possible electrical short
Old Feb 3, 2005 | 10:24 AM
renegade888's Avatar
yamaha uses a neutral relay. When the bike is shifted into neutral there is a switch by the shifter that is closed and sends a signal to the relay. (possibly located above the left rear wheel next to another relay.) I recommend getting a wiring schematic. THe dealers will sell or share them. If you can't locate one email me. I also would suspect a bad main line connection such as the main fuse holder to cause the blinking. A porrly installed nuetral switch or a bad nuetral switch could keep the light on along with relay going bad.
Old Feb 3, 2005 | 03:53 PM
deathmetal's Avatar
Yeah im going to let him know. The weird thing about it is that the lights and the neutral light go along in perfect sync. On/off/on/off there's no "loose connection" symptoms on it so it just seemed like maybe its a signal for a problem. At any rate ill run along the wires and check it. thanks a lot.
Old Feb 3, 2005 | 06:31 PM
warrior007's Avatar
Very interesting, Im sure its something he did. did he put the sensor wires back on the motor in the right spots ? (neutral and reverse sensors hook up different so its not really possible unless they were cut and rewired)
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
JoAnnS
Jul 23, 2015 02:18 PM
Derek Allen
Jul 22, 2015 09:25 PM
black_thunder
Jul 22, 2015 06:01 PM
