What is a Hot Start Lever??
Old Feb 2, 2005 | 08:01 AM
HighFlyin's Avatar
Default What is a Hot Start Lever??
I was just curious what is a hot start lever and what its purpose is?
Old Feb 21, 2007 | 08:22 PM
NickOgozaly's Avatar
it is used mostly by people who race(MX). And it is supposed to start your quad with having to kickstart it.
Old Feb 21, 2007 | 08:48 PM
u1arunit's Avatar
How does it work?
Old Feb 21, 2007 | 09:09 PM
i'm sorry i was thinking of something else[img]i/expressions/face-icon-small-blush.gif[/img], actually a hot start helps you start a Dirtbike. It fires up the piston. say your dirtbike stalls just press the hotstart lever and it fires right up.b/c more and more dirtbikers are upgrading there cams, valves, and carbs this hotstart makes it easier to start you dirtbike. it fires up the monster inside!
Old Feb 21, 2007 | 09:45 PM
u1arunit's Avatar
So then this must be a compression release feature like Husky used to use on the older big bore bikes years ago?
Old Feb 21, 2007 | 09:48 PM
bigdad390's Avatar
A hot start lever is basically a compression release often incorporated into the clutch handle, allowing easier retstarting in gear.
Old Feb 21, 2007 | 10:33 PM
crazy700yammy's Avatar
I thought a hotstart lever was used on four stroke dirtbikes to help start them when the motor was hot. If your bike stalls during a race a four stroke sometimes takes several kicks to start. I thought the hot start lever thinned out the amount of fuel going into the motor while kicking it over to help it start faster. This is just what I was told though, don't know if it is fact. Had one on my old Yamaha WR250F bike.
Old Feb 22, 2007 | 02:41 PM
54warrior's Avatar
The hot start lever is used when you stall the bike during a race. My understanding is that it allows cool air to enter the engine through the carb providing for easier startup. Supposed to save your leg from kicking so damn much. If you've watched any SX races, you've probably seen the way the kick and kick and kick and kick and kick and kick to get them started. It's about 75% effective, IMHO. You don't need it on an electric start machine (the battery provides enough oomph to crank it over).
supermanotorious
Mar 12, 2021 11:02 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
joshuafromny
Jun 22, 2015 05:30 PM
Shooterj2003
Jun 21, 2015 07:51 PM
1000gade
May 27, 2015 12:37 PM
