yfz 450 problems with cutting out mid range
Old Feb 2, 2005 | 09:20 PM
ARyfz450's Avatar
Default yfz 450 problems with cutting out mid range
Ok. I have a 05 yfz 450. I have recently installed hotcams (intake and exhaust), gyt-r slip on exhaust, aluminum air box with k&n filter. carb jetted 180 main 48 pilot needle in 4th position and 1.5 turns on fuel screw. I am having problems with the bike cutting out at mid range when cruising. I put all the parts on at once and got the jetting specs from hotcams. can anyone help me out??
Old Feb 2, 2005 | 10:17 PM
rc3's Avatar
rc3
Which needle are you running!
Old Feb 3, 2005 | 08:14 PM
ARyfz450's Avatar
I am running the ncvq (or something like that) needle that comes in the gyt-r jet kit. also my elevation is around 1000-1200 above sea level.
thanks
Old Feb 3, 2005 | 08:22 PM
rc3's Avatar
rc3
Well I am running the same set up, except stock cams with the cam mod, and I run the same needle on the 4th clip, but I am only running 170 main, and I have no problems, anyone else have any suggestions, is cutting out just cruising, or when you are really on it, rich blubber sound or a lean sound,
Old Feb 3, 2005 | 08:29 PM
ARyfz450's Avatar
just cuts out cruising, everything fine WOT. not sure the sound just know that its annoying!
Old Feb 3, 2005 | 08:36 PM
ARyfz450's Avatar
also before I got the jetting specs from hot cams I had 170 main, 45 pilot, stock turn on fuel screw and needle in 6th position and it did the same thing. I just didnt know if maybe I got off 1 tooth on the cams and maybe that is causing it or if it is the jetting. I havnt pulled the plug yet to see what color it is yet either.
Old Feb 3, 2005 | 08:55 PM
rc3's Avatar
rc3
that would be my next guess, because your jetting is pretty dang close to where you need to be, and if it is running as bad as you say, something has got to be off!
skinnyr6
Aug 25, 2023 02:18 AM
hugemoth
Jul 20, 2020 03:28 AM
Nondem
Feb 22, 2020 12:20 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
steveo612
Jul 11, 2015 08:35 AM
