shock problems
Old Feb 6, 2005 | 06:55 PM
ridinsmooth's Avatar
Default shock problems
mly shocks on my quad make a sqeeking noise and i dont know how to stop need advice
Old Feb 9, 2005 | 11:43 AM
honda450es4x4's Avatar
you take wd40 and spray it it the upper sleave of the shock, and then push down on the rack to see if it stopped.
Old Feb 9, 2005 | 04:42 PM
313racing's Avatar
sounds lyk a lot of work but is not
jack up the qud and take out suspension tht is sqeeking and spray the bushing both lower and upper wit
wd40 or a type of grease grease wood keep the sqeek awaay for the longest period of time
wd40 only works for bout 2 weeks or 3 weeks
thanxs 4 the question
Old Feb 9, 2005 | 10:57 PM
JTRider's Avatar
I have the same problem with the front left shock on my Rancher. I checked the bushings and spring. The problem seems to be in the shock itself. Just like the guys say in the other replys, spraying with WD-40 or PB Blaster helps the most.
Old Feb 9, 2005 | 11:24 PM
dzzy's Avatar
MDRracing313 has the right idea. If the Rincon is like a Rancher, and it probably is...jack it up, easier to remove the front tires, remove the bottem shock bolt, push on the A arm and remove the bottem of the shock from the arm, pull out the metal collar and slather some good grease on it and the bushing, reinstall.
Captjay
Jul 23, 2015 12:33 PM
1966F100
Jul 12, 2015 03:08 AM
1966F100
Jul 12, 2015 03:01 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
