fouling plugs
Old Feb 8, 2005 | 01:41 PM
force2's Avatar
Default fouling plugs
I live in southern minnesota and have a stock 650 praire it fouled an plug so i thought its time to check the choke cables and the plungers and they are fine, so now i want to rejet anyone got any helpful info on what jets to run and where to set the air mixture at , any info would help thanks
Old Feb 8, 2005 | 03:15 PM
TallTexun's Avatar
Hey Force 2!
I am going through that same think now. The main and pilot jets in the carb on my Prairie came from the factory with jets for sea level operation.
I had to call the dealer and get the correct part number.
There may be some after market retailers with the same info, but I wouldn't know bout that.
All Kawasaki dealers should have the info you need.
good luck
bob
Old Feb 8, 2005 | 09:42 PM
tuffEnuf's Avatar
Force2 & TallTexan visit: http://www.smellofdeath.com/lloydy/jetting.htm
Both of you save yourselves the trouble and visit your hardware store prior to starting jet job and get you some metric allen head screws(need matching allen head wrench also) in .04 X14MM and replace your Carb bowl screws (Need 16 to replace top & Bottom). Stock phillip head sscrews strip very easily.
Easiest way I've found is to get at the carb bowls is to remove top CVT exhaust clamp, fuel petcock, and right side coil. Once items are laid aside you can access all the bowl screws. If you got to adjust needles I've found removing the air filter housing/plastic allows access to top Carb cover screws/needles.
Happy Trails,
TuffENuff[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 8, 2005 | 10:32 PM
Kenskiv's Avatar
Happy Trails,
Thanks for the heads up...
search button ownes me......LOL
Old Feb 9, 2005 | 09:43 PM
TallTexun's Avatar
Hey Ken:
Thanks for the reply. I am rejetting cause it's a new machine, jetted for sea level, and I live at 6500 foot elevation.
Hard to start, and running rich. I am taking it back where I bought it in Odessa Texas to have the work done.
I will ask the service manager to do what you suggest.
bob
Old Feb 13, 2005 | 10:29 PM
force2's Avatar
figured out the problem the choke plungers were not returning to the home position i got some heavier springs and it works fine thanks to everyone for the help
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
