lakota smoking
Old Feb 11, 2005 | 10:26 AM
beerbq's Avatar
Default lakota smoking
I have a 98 lakota that smokes on and off. Has anyone had a problem like this. It fouls plugs also (oily). Could this be piston rings or bad valve seals? Any help would be appreciated.
beerbq
Old Feb 11, 2005 | 11:16 AM
tuffEnuf's Avatar
Do a compression check. Weak valve guide seals will allow oil seapage into your cylinder, so will a bad or weak choke spring or carb float. Do not leave your fuel on after done riding.
Old Feb 11, 2005 | 04:39 PM
holeshotz8436's Avatar
i am having the same problem with mine, i took it to the dealer and the whole top end is bad and needs to be rebuilt. You could just have a bad piston wring or valve seal but you should get it checked out because its only going to get worse......................
Old Feb 14, 2005 | 10:22 AM
beerbq's Avatar
Thanks for the suggestions. I am going to check the carb first.
beerbq
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
