Lightened flywheel on the scrambler?
Old Feb 11, 2005 | 09:17 PM
Sandunr0503's Avatar
Default Lightened flywheel on the scrambler?
Anybody have the lightened flywheel on the scrambler? one pound or 2.3 pound lightened?
Old Feb 11, 2005 | 10:04 PM
CED's Avatar
CED
Mine has 2.3 lbs removed,i removed the battery and starter.It makes a big difference in rev's and throttle response.
Old Feb 12, 2005 | 12:19 AM
POLARISFREAK's Avatar
Ced's right, revs much faster and you can loose the battery and starter and shed some weight. If your drag racing alot, it's the only way to go!
Old Feb 12, 2005 | 01:43 AM
EAB's Avatar
EAB
I went with the trail lighten, 1 pound off. I couldnt bring myself to ditch the elec start yet. If I had known how easy it was to remove the flywheel I would have gotten it lightened a long time ago
Old Feb 12, 2005 | 02:27 PM
paulzaho's Avatar
This may sound like a stupid question but.....Can a flywheel be lightened on an '04 4X4? Will it make much difference?
Thanks for any help. Paul
Old Feb 12, 2005 | 03:29 PM
tbsleeper's Avatar
i dont think it works taht good of 4strokes
Old Feb 13, 2005 | 07:22 PM
teallenjr's Avatar
How hard is it to remove the flywheel? Can you do-it-yourself? If you remove the starter do you plug the hole with a cover or what?
Old Feb 13, 2005 | 07:46 PM
conig's Avatar
teallenjr
you can get a starter block off from rcr, hpd, and I think hotseat.
I made my own block off plate, if you have some scrap metal and alittle time and the tools its pretty easy.
you also have to get some type of capacitor so you can keep your lights, like a white brotheres battery eliminator.
Old Feb 19, 2005 | 01:27 PM
teallenjr's Avatar
How easy was it? I took the center bolt out of the clutch but it didn't move. Do I have to remove the smaller bolts around the clutch. How exactly does it come apart. 95 scrammy looking for quick response, bottom end.
Old Feb 19, 2005 | 01:30 PM
thewayout420's Avatar
you need a clutch puller to get the primary clutch off..
