Lightened flywheel on the scrambler?
Old Feb 19, 2005 | 01:30 PM
teallenjr's Avatar
Default Lightened flywheel on the scrambler?
Polaris freak- you still got your flywheel on. Thinking of removing mine on the 95. Can you help a amatuer.
Old Feb 19, 2005 | 01:36 PM
thewayout420's Avatar
when you say your thinking about removing yours,you mean reamoving it to have it lightened and then putting it back on right?
Old Feb 19, 2005 | 02:30 PM
POLARISFREAK's Avatar
Most harmonic balancer pullers will work for getting the flywheel off!
Old Feb 19, 2005 | 02:31 PM
Troyer23J's Avatar
Originally posted by: teallenjr
How easy was it? I took the center bolt out of the clutch but it didn't move. Do I have to remove the smaller bolts around the clutch. How exactly does it come apart. 95 scrammy looking for quick response, bottom end.
The flywheel is on the opposite side. Behind the recoil housing. Pull the bolts out around that, then the flywheel is right there.
Old Sep 15, 2005 | 01:30 PM
  #15
zilla24's Avatar
I too was thinking of lightening my flywheel somewhere close to a "trail" mod, that way I can still use the e start. I would rather machine this myself since I have access to a machine shop at work, anybody get the trail mod done on theirs and know what was machined on it and possibly some dimensions? [img]i/expressions/face-icon-small-happy.gif[/img] Thanks as always for the help!
Old Sep 15, 2005 | 03:51 PM
  #16
scramblered's Avatar
trail mod lighten flywheel is around 1 lbs romoved and still using electric start,while a race mod flywheel is 2.3 lbs romoved (that from hpd),and no electric start anymore.
both give a better throttle response and help motor to build rpm faster whenever the positions is,the flywheel is located at the right side of the round housing case of the engine.
Old Sep 15, 2005 | 06:38 PM
  #17
zilla24's Avatar
Do you know where the material was removed from? Was it the OD or face of the flywheel?
Old Sep 15, 2005 | 06:56 PM
  #18
rieds's Avatar
is trail lightening the flywheel usefull for the average trail rider? i'm just gettin used to the mods i've had done and was wondering how much difference doing this and adding a 39pwk carb and a hi-po ignition would make over what i've allready had done?
Old Sep 15, 2005 | 07:17 PM
  #19
DemonDS's Avatar
Good questions there. Watching for the answeres to them!!
Old Sep 15, 2005 | 07:26 PM
  #20
duneaholic's Avatar
The trail lightened flywheell would be great for trail riding. It revs up noticeable faster. Anytime you can remove weight from rotating mass you are going to up performance. The Race lighten flywheel eliminates electric start and I just don't want to do that. The 39 pwk carb is by far a better performing carb than the stocker. The HPD ignition is a great product but have no first hand knowledge on how well it performs.
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
