Low Range Question
Old Feb 16, 2005 | 10:29 AM
BlackRaptor's Avatar
Default Low Range Question
On my Explorer 400 is a 2-stroke so not a lot of bottom end so i when i go ditch riding with it i almost always keep it in low range and it seems to do well. My speed ranges from 5mph upto 25 when the wheels are spinning and get to 20 in the clean ditches.
My question is it wines in low so is it harminging it running it in low at higher speeds.
I can't see how it could but i figured i would ask.
Old Feb 16, 2005 | 11:24 AM
mnorton's Avatar
I don't think it will hurt it, in fact I have heard that it is good for the machine to occasssionally run it in Low. Good luck!
Old Feb 18, 2005 | 12:08 AM
95sport400's Avatar
I do the same with mine quite often. I'll ride even faster than that in low range. Unless you're overrevving the engine, it should't hurt anything. Also gives great throttle response on tight, twisty trails.
Old Feb 18, 2005 | 12:13 AM
spyder6's Avatar
my low ends at about 15 MPH so im riding in high most the time
Old Feb 18, 2005 | 01:43 AM
Thats what i figured
but i was on here and thinking about it so i thought i was ask
tomorrow is friday and i'm going to ride untill i fall asleep on it.
Old Feb 18, 2005 | 03:56 PM
spyder6's Avatar
check your oil [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 18, 2005 | 07:00 PM
Kudzu's Avatar
As long as you aren't near redline all the time, you're fine. 2 strokes like to run. Think about how they work - the fuel/oil mix lubes the engine, so at higher revs you get more lubrication. Most people also don't realize how much the fuel going through an engine cools it. A 2 stoke makes its power at higher rpms for a reason. Actually, you are lucky you have the low range. My Scrambler 400 doesn't, so you either go everywhere fast, or you're running below the powerband.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bigred20653
Oct 2, 2015 10:05 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Myronh
Sep 8, 2015 11:27 AM
braap123
Sep 7, 2015 10:57 AM
