simple clutching question on scrammy
Old Feb 17, 2005 | 11:37 AM
Gopher500's Avatar
Default simple clutching question on scrammy
ok, i do NOT want to raise the engagement on my scrambler. in reality, i want to lower my engagement. i do a lot of slow technical riding at speeds of 3-5mph, so a higher engagement just screws me over. anyone here know how i can lower my engagement from the stock? i want it so i just breath on the throttle and its rolling
Old Feb 17, 2005 | 12:17 PM
TJCINC's Avatar
check out this site www.hpd-inc.com they have clutch springs, contact your local polaris and find out what the spring rate #'s are then compare them to the one they have , maybe you will find one with less, you may also want to change your clutch weights, you might want to call rick ritter of rotter cycle , he helped me find the right parts to make my bike do exactly they way i ride , man its great now from the stock clutching. good luck.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 17, 2005 | 12:23 PM
braveops's Avatar
pm brambles he got one of daltons springs with low engagement ask him what he thinks of it here is rick ritters spring chart to compare
I tested several manufacturers primary springs on a spring scale today . I had a total of 12 springs ,they were all brand new .
My readings may vary from the manufacturers , but the whole point of this is to show springs relations to each other . My scale is repeatable to a variance of about 3 pounds , I have checked this by retesting the same spring several times . I do find springs (of the same color code) can vary often by more than that.
I always thought an EPI red and a polaris white were identical . The two springs appear to be the same , and maybe they are , I may have gotten a wimpy white spring . I tested several EPI reds and they all tested close together , the polaris white is just a little lower . I have another new white spring coming to test tommorow .
My scale is not a high quality certified scale , I am using a common bathroom scale in my press with a tool I made to hold the spring and allow me to compress it while I read the calibrations on the side .
The poundage may be off but the tests are repeatable with in the variances I have previously mentioned .
I put this list together so at least we can all see how these things measure on the same day , on the same tester .
I hope this helps you all in tuning your clutches .
Color 2.5" 2.25" 2.0" 1.75" 1.5" 1.25"
Polaris blue/green 5 24 46 66 90 117
Dalton plain/white 13 30 47 65 86 105
Dalton blue 3 26 52 81 111 145 <--just added
Polaris white 34 52 72 93 116 140
EPI red 37 57 76 97 118 140
Dalton black/white 39 57 77 100 122 144
Polaris green 43 61 78 96 116 140
Dalton black/orange53 71 88 106 125 150
Aaen green 54 73 91 112 130 154
EPI orange 79 91 102 118 130 145
HPD plain 32 65 102 145 185 235
Polaris orange 72 92 115 141 166 196
HPD red/yellow 118 139 161 187 214 243
HPD red 135 162 183 206 229 253
Dalton Black/red/white147 177 204 234 267 298
HPD violet 153 179 206 229 252 281
EPI maroon 199 228 245 277 303 330
I just added HPD violet.
Edited: Fri August 08, 2003 at 2:27 PM by RickRitter
Old Feb 17, 2005 | 12:48 PM
Gopher500's Avatar
well i just sent rick a email on what im looking for. now im pretty new to clutching, but from what ive "aqquired" a heavier spring raises the engagement? am i correct or wrong? also, how do the weights affect the engagement?
Old Feb 17, 2005 | 01:11 PM
braveops's Avatar
yes u are right heavy spring will up it some and the weigts are the other way
Old Feb 17, 2005 | 04:03 PM
BigBadScrambler's Avatar
Rick usually doesnt have time to check his emails. You are better off calling him. He answers the phone himself and will set you up with exactly what you need. Great guy.
Old Feb 17, 2005 | 04:30 PM
Bubba297's Avatar
You will have to move more than a gram or two of weight to see any engagement change to speak of. The spring is usually the big thing to determine engagement changes. You could put a lot of weight in with a weak spring, but then your bike will be sluggish due to the clutch trying to shift too fast.
You can call Aaen and talk to Olav. They can custom grind you a set of weights that have more weight on the tip and can help create a lower engagement. That along with a different spring could accomplish what you want.
ghost civic
Jan 15, 2020 07:43 AM
Kyle5050
Dec 13, 2019 04:25 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
