lt80 carb upgrade need input please..
Old Feb 24, 2005 | 07:52 PM
ltdaddyo's Avatar
Default lt80 carb upgrade need input please..
I have a modded lt. port polished clutches bored out. iam running the stock carb and was wondering if i would get any more out of top and bottom end if i go to a bigger setup and where i could get one....thanks
Old Feb 24, 2005 | 11:21 PM
1fastpolaris's Avatar
I would think so. You could get one at midwestmini.com I would talk to Jack (LT80) cause I think he can modify your stock carb. Just click on Moore for his email address
Old Feb 24, 2005 | 11:50 PM
ltdaddyo's Avatar
Thanks one fast polaris Il like the hole shot I have now just lookin for a little more my lt was built by hetrick. they did a nice job . ill give moore a try . do you know price range of a stroker kit?????
Old Feb 25, 2005 | 11:07 AM
LT80's Avatar
LT80 Expert
Some think 20mm helps alot. Call DG and get one.
FYI: tell em your from Joes cycles or whatever,and you'll get the dealer discount (175)[img]i/expressions/face-icon-small-wink.gif[/img]
You should put in a thicker reed when going to a 20mm.
Old Feb 25, 2005 | 12:34 PM
Hymis's Avatar
Hello, Im sending my motor and carb out to CT Racing. CT says they can modify the stock carb to make it run better then a lager 20 mm carb. Also gives better throttle response. Good luck
Old Feb 26, 2005 | 11:39 AM
LT80's Avatar
LT80 Expert
CT says alot. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 26, 2005 | 01:16 PM
ltdaddyo's Avatar
Thanks LT80 . its really somthing tweaking these minis ..
Old Feb 26, 2005 | 01:32 PM
LT80Pops's Avatar
Hey Jack, would I benefit any on the topend with a 20mm carb? Did you do anything to Chris's carb when I sent you the motor or did you just rejet? Also if you think that the carb would help any, which reeds do I need to get to go with it? Thanks, Russ.
Jmuddin284
Jan 19, 2026 07:16 AM
Ean
Dec 19, 2022 08:48 AM
GregM
Mar 6, 2018 06:53 AM
Wnthunting
Jul 9, 2015 03:02 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
