LT80 Clutch Please help!
Old Feb 25, 2005 | 12:32 PM
Hymis's Avatar
Default LT80 Clutch Please help!
Hello,
I'm trying to remove the rear clutch assembly on an LT80 so I can send it off to CT Racing. Can anyone give me any insight on how to remove this thing? I removed the small main nut, now there is a large flat nut.
I'm not sure if I'm supposed to remove that nut aswell. It's very large, maybe a 34-37 mm. Is a special clutch pulller tool required? Thanks for your help!
Old Feb 25, 2005 | 03:28 PM
asfasasu3's Avatar
That nut does have to come off to get to the clutch weights and spring. It is LEFT hand thread. Opposite the smaller, outer nut. Once you have this nut off, it should come apart. The larger nut does not hold it on, it just holds the clutch together. Try pulling it off before you do anything to the large nut, it should come off.
Try this for a a look see how its built .http://216.37.204.205/Suzuki_OEM/Suz...pe=13&A=91&B=5
Old Feb 25, 2005 | 04:49 PM
Hymis's Avatar
Asfasasu3,
Your the man! Thanks for the help.
Old Feb 27, 2005 | 03:52 AM
1fastpolaris's Avatar
I would send it to Jack (Lt80) Moore. He know his crap about lt80's
buddieboy
Dec 9, 2016 05:50 PM
QuadRiders
Oct 22, 2015 04:13 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
