My new 145 jet doesnt have a slot in it for screw driver?
Old Feb 26, 2005 | 06:53 PM
Plainsman's Avatar
Default My new 145 jet doesnt have a slot in it for screw driver?
This must be the wrong one correct? It is a Klein (sp) 145 but its longer and hex shaped.
So if I dont to 142/145 should I shim to .02 or .04?
Thanks !
Old Feb 26, 2005 | 09:52 PM
ranger696f's Avatar
some jets only have the hexed heads and some only the flat slots for screwdriver double check the kit and if it is the right one then use the hex socket that fits
Old Feb 26, 2005 | 10:45 PM
hondabuster's Avatar
If it has a hex head, and is longer....you got the wrong one. The threads are most likely different as well.
keihin jets
If you look at this page, The jets you need are the second one down, for cvk carbs. Youve got the jets for the third one down, with hex heads, for totally different carbs. All are keihin, but use different jets. Even if you could thread them in....dont. Get the correct jets, and youll be much happier.
Shimming the needles and making the mains bigger, effect two different throttle positions. The needles effect 1/2 to 3/4 throttle, and the mains effect 3/4 to full throttle.
Old Feb 27, 2005 | 01:00 AM
Plainsman's Avatar
Mine look like the 3rd one down, not the second. So I guess I got the wrong stuff [img]i/expressions/face-icon-small-sad.gif[/img]
The threads fit fine, its just long.
Darn dealer.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
