Clutching for scrambler?
Old Mar 1, 2005 | 02:48 PM
SramblerPower's Avatar
Default Clutching for scrambler?
What is the best combo of clutching for the scrambler. I have a roller secondary but I can change it to the old one if there is better combo with stock one. They say that the roller clutch is better than the standard secondary.
Old Mar 1, 2005 | 03:46 PM
Drttrack97's Avatar
The roller secordary is better them your stock one. Call Darrel at HPD and he can match a primary clutch to your ride style and terran. http://hpd-inc.com/index.htm
Old Mar 1, 2005 | 08:21 PM
scramblerXrated's Avatar
i recently upgraded my clutching to an orange primary with 10-62 weights and a purple secondary spring.
all i gotta say is wow!! you really gotta hold on! it will drive right out from under you!!!
X
Old Mar 1, 2005 | 11:04 PM
ftwflh's Avatar
I run a Hotseat TEAM roller with a 54-44-40 helix with a yellow polaris primary spring and 50.5 gram weights and it does great on my 500 Scrambler.If you want a more agressive engagment you could try a brown spring with 10-56 weights.But my set up is for low engagment and fast shiftout with tons of midrange power. I have a question for you!What size of jets are in your carb and how many disc are you running on your muffler? Brad
Old Mar 2, 2005 | 12:19 AM
I have all the discs and I can't remember what size of jet is in it now. I no that it is smaller than stock and that the needle is set at a different position.
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
