How to clean your stock airfilter
Old Mar 3, 2005 | 11:37 PM
ridinsmooth's Avatar
Default How to clean your stock airfilter
is it hard what do i have to do to clean it
Old Mar 4, 2005 | 01:23 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I spray it with PJ1 foam filter cleaner. Put it in a plastic bag (so it doesn't dry out) and let it sit a few minutes. Squeeze out the excess cleaner, then rinse it thoroughly with water FROM THE INSIDE OUT. Squeeze out he water (but don't wring it), then let it air dry. Always be sure it is completely dry before reoiling. I like super-tacky Maxima FAB for reoiling.
Some folks use an organic solvent to remove the old oil, but in my experience all this does is disolve the oil, and leave the heavier dirt behind. Rinsing it with water from the inside out, washes the dirt out.
Old Mar 4, 2005 | 02:25 AM
Exrider22's Avatar
check your manuel
Old Mar 4, 2005 | 11:20 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
The manual for the 450r recommends using kerosene to clean the foam filter. That is what I've always used to clean all the foam filters. I use a spray on foam filter oil. Less messy than the bottled variety.
Old Mar 4, 2005 | 08:42 PM
Red Rider
I never could figure out why Honda recommends the Kerosene thing. Like I said, it dissolves the oil, but doesn't flush out the dirt. Just leaves it behind, trapped in the foam........go figure.
Smooth-How long you had your machines? And you never cleaned the filters before? No dust in Arkansas?
Old Mar 4, 2005 | 10:31 PM
garrett5462's Avatar
or u could just take an air compressor and put a air blower on it, take the foqm off the filter, spray it down good with carb clean, spray it with the air. put more carb clean and do the same thing a few times. then, let it dry and put her back in.
slowgsxr97
Mar 18, 2022 03:40 AM
WilliamBos
Jul 25, 2015 02:41 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
