AWD button not working?
Old Mar 4, 2005 | 03:50 AM
tp4meyebunghole's Avatar
Default AWD button not working?
1995 425 Magnum 4x4: I just got this running and had it out yesterday engine seems strong but when I hit the AWD button nothing happened. I did some rewiring on the lights because they were all screwed up, so i'm thinking that maybe the AWD wiring is messed up too. I got this thing for $400 bucks, I can't complain too much. I've never owned a polaris before, should I hear anything engaging when I hit the AWD button? because i'm not hearing anything. I have four wires running out of the switch 1 yellow, 1 brown, 1 gray, 1 gray w/ white stripe. All 4 run into the box on the left side of the gas tank. Does this seem right?
Rob
Old Mar 4, 2005 | 07:58 AM
kingdiamond's Avatar
i had the same problem,ended up being the switch inside the shifter was broke...not the awd button or wiring... good luck...
Old Mar 4, 2005 | 09:11 AM
PolarisUK's Avatar
"I have four wires running out of the switch 1 yellow, 1 brown, 1 gray, 1 gray w/ white stripe"
According to my wiring diagram in the Haynes manual your four wires are as follows...
Yellow - Headlight
Brown - Ground wire for AWD indicator light
Grey - (English spelling [img]i/expressions/face-icon-small-wink.gif[/img] ) Switch to front wheel drive coils and AWD indicator light.
Grey/white - AWD Switch to the over-ride switch and Trans switch.
Check the voltage at the front wheel drive coils (with the switch ON), between the end of the grey wire and a ground point - if there's no voltage you have a bust switch, if there's a voltage your coils are bust. Not sure how easy the latter would be to replace.
Good luck...
Old Mar 4, 2005 | 09:15 AM
PolarisUK's Avatar
Obviously the two to test at the switch end are the Grey and Grey/White ones... assuming, of course, that nobody's changed the colour of the wires!
Old Mar 4, 2005 | 10:37 AM
Thanks Polaris UK!!!! are you sure it's not gray? LOL, but where do the wires from the switch actually connect to. Mine run into the box on the left side of the gas tank, not sure of the name, not too good electrically. What is a good ground source by the way?
hugemoth
Jul 20, 2020 03:28 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
