What is the best way to see if your steel clutch pates are bent?
Old Mar 5, 2005 | 07:48 PM
jackass650's Avatar
Default What is the best way to see if your steel clutch pates are bent?
I have read a few past posts about putting them on a flat steel table or a peice of glass or a steel ruler? thanks
Old Mar 5, 2005 | 09:39 PM
hondabuster's Avatar
Yep...a piece of glass is flat enough. Then use shim stock, or feeler gauge to check the size of the gaps.
Old Mar 6, 2005 | 12:59 AM
jackass650's Avatar
what is the max they can be? my cdrom says that the steel driven maximun warpage should fall through a slot of 1.63mm (.064 in.) what the hell does that mean? thanks again fellers
Old Mar 6, 2005 | 01:23 AM
Measure the plate thickness. With a mic if you have one. Subtract that measurement from .064. The remainder is the tolerance. Actually its about 1/2 that much, because if you can get .005 " under the glass from one side, the other side is up .005.
So if the plate measures .054, then .064 minus .054 = .010", which means you can be warped .005 per side.
Joe454
Nov 20, 2020 01:19 PM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
meddy0388
Sep 9, 2015 06:41 AM
