99 Recon Serial #
there should be at least 2. one should be on the VERTICAL frame rail by the front left tire (as if you were sitting on quad), and is a paper one that is taped onto the rail. this one can eventually come off from pressure washing. the other one is at the front of the quad on a plate and is stamped onto the plate. you need to look below the front rack, and slightly above the front bash plate.
