What are the common modifications done to a Banshee to make it powerful? Can you describe the installation of each item?
Old Mar 7, 2005 | 11:10 PM
ehlitdew's Avatar
Default What are the common modifications done to a Banshee to make it powerful? Can you describe the installation of each item?
Can you describe the installation of each item? (Could you please describe it in detail)
Old Mar 7, 2005 | 11:29 PM
NastyNate03's Avatar
a set of pipes pro flow K&N filter with outerwear set of reeds and rejet your carbs and you will have a fast banshee with good power all around
Old Mar 7, 2005 | 11:39 PM
ehlitdew's Avatar
Could you please explaine each modification in detail.
Can you please also explain the purpose of the change, for example so that the oil follows fast or the air follows fast, and so on.
Old Mar 8, 2005 | 08:04 AM
ZimRaptor's Avatar
k&n air filter- the more air your engine can breath the more gas mixture it can use = more horsepower, easy to install, take off your seat and remove the plastic top of the box u see
aftermarket pipe- the stock pipe restricts a lot of air flow getting out, with a full aftermarket exhaust system ur engine will run a lot quicker and gain a good amount of horsepower, (if u dont know what a pipe is u shouldnt be riding)
v-force reeds- reeds are tucked in behind your carburator (thing on the side of block, running a gas line [img]i/expressions/face-icon-small-wink.gif[/img] )
the stock ones are considered crap pretty much because aftermarket ones help a lot in the horsepower department, again letting more air into the engine, in this case a lot more
Old Mar 8, 2005 | 11:00 PM
ehlitdew's Avatar
Thanks body, appreciate it, it was pretty cool explanation.
By the way is this what you were talking about in item one?
http://www.yamaha-motor.com/accessor...37/detail.aspx
Air Filter
Old Mar 8, 2005 | 11:07 PM
AustinONeal's Avatar
heres what you need to make some power
http://www.magicracing.com/product.a...=1109&catid=56
Old Mar 9, 2005 | 12:04 AM
ImASissy's Avatar
in contradiction to your statement on the reeds. Banshees are known to have pretty decent STOCK reeds. I am sure that you would get a little bit of a horsepower gain... But like i said the shee stock reeds aint too bad. However, i did spend that extra $200 to get some aftermarket reeds.
Old Mar 9, 2005 | 02:11 AM
ehlitdew's Avatar
wasup dude, how is it goen
thanx for the clarification.
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
B4NSH333
May 26, 2015 06:55 AM
