Blaster oil-injection block-off
Old Mar 8, 2005 | 04:03 PM
Bakobanshee's Avatar
Default Blaster oil-injection block-off
Do you have to install a block off kit even if you empty out the resevoir and start running pre-mixed gas in the tank? Will anything bad happen if you run the bike like this without installing the block off kit?
Old Mar 8, 2005 | 04:11 PM
daputz's Avatar
The pump could pump air into the carb, thowing of the air fuel mix. Without the oil passing through the pump it could also seize.
A cheap way to remove it (dissable it) is to pull the pump out and remove the white plastic gear. Then reinstall the pump body, and block off the oil port at the carb (use something like jb weld).
Old Mar 10, 2005 | 05:12 AM
the oil is pumped through a plastic hose and into the carb right? If so, then i could just snip that hose and plug it and I should be ok right? Pumping air into the carb sounds exactly what might be happening to the blaster. Zero bottom-end and doesn't want to idle right. When you blip the throttle it has very poor throttle response!
Old Mar 11, 2005 | 11:45 PM
Fastblasterboy's Avatar
It would prolly be easier just to buy the block off kit.
Old Mar 12, 2005 | 12:03 AM
yamahawarriormods's Avatar
yeh you dont want to just clip the hose and block it off cause u will burn out the bump dont quote be cause i have never had to do it but i see the bock off kits are real cheap.......
Old Mar 23, 2005 | 03:36 PM
disasterblaster's Avatar
make your own kit. A piece of medal to cover wher the pump goes and a plug for where it connects to the carb. i did and it works fine.
Old Mar 23, 2005 | 05:34 PM
Shav0's Avatar
You cant just plug the hose and leave the pump still running. Do what daputz suggested and remove the gear on the inside.
STLyamwar
Jul 25, 2020 04:44 AM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
