gearing
Old Mar 10, 2005 | 01:23 AM
MTX's Avatar
MTX
Default gearing
What front sprocket should I change it to, Big Gun full exhaust, and sand skate 2s 20x11x10, weight around 170, should drop it to 15 ? Or 14 with the 20" tires ?
Old Mar 10, 2005 | 07:02 AM
w1ngnut's Avatar
Default gearing
I would just drop it to a 15. I have a 15 with 20 inch paddles and its just about perfect for me. With your weight u could probably pull 3 and 4th gear all day at the dunes.
Old Mar 10, 2005 | 09:24 AM
Budman650's Avatar
Default gearing
Ive got rw stage 1 kit and 20" tires. I have a 14 and 15. Tried the 15. It will slow you down top end. In the slower dunes, I was constantly shifting between 2nd and 3rd and it got annoying so I switched back to the 16. I hear 22" tires are best with the 15 tooth. PM me if you want to try or buy them. See you at Nascar this weekend.
Old Mar 10, 2005 | 10:22 AM
SCOUNDREL's Avatar
Default gearing
I have a 14T and a 15T as well as the stock 16T. To answer your question it really depends on the terrain and whether you looking for top speed or low end grunt. With 20" tires I would suggest a 15T. With 22" tires I would switch to the 14T but then again I'm not concerned with overall top speed.
Here is a link that has a gear calculator. click on the "Gear Calculator" on the right of the page.
Gear Calculator
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
