Question about steering stem bearing?
Old Mar 10, 2005 | 01:28 AM
jackass650's Avatar
Default Question about steering stem bearing?
does the bearing on the bottom of the stem go through the hole in the frame with a collar on top of the frame and one below the frame or do both collars go around the bearing sitting on top of the frame or both collars below the frame? i just took mine out and the guy i bought it from had both of the collars below the hole in the frame and I dont think that is correct, thanks fellas
Old Mar 10, 2005 | 03:45 AM
BOMBSAINT's Avatar
both collars go around the bearing and then bolt to the top side of the frame. i had to replace that bearing so i remember.
Old Mar 10, 2005 | 04:28 AM
jackass650's Avatar
cool thanks bombsaint I had alot of play in my steering stem so I ordered a bearing thinking it was bad, pulled it all apart and found out it was dry but now I know why it was sloppy thanks brother
Old Mar 10, 2005 | 06:26 AM
TheChosenOne's Avatar
Confirmation on that one bombsaint.
Old Mar 10, 2005 | 07:26 AM
mudnuri's Avatar
Ditto.
Make sure you use a touch of loc-tite. Mine came loose.
Ean
Dec 19, 2022 08:48 AM
Sportsman850
Jul 31, 2015 04:25 PM
Gtsordo
Jul 22, 2015 01:27 PM
mdrkcckv
Jul 22, 2015 09:10 AM
1966F100
Jul 12, 2015 03:01 AM
