kazuma 150
Old Mar 10, 2005 | 12:24 PM
GDiddy's Avatar
Default kazuma 150
How tight should the chain be on a 150 kazuma. I read some previous posts about it but don't know how tight or loose it should be. I am getting 2 macnines in a few weeks. You can email me direct at Gerling@wcs.k12.mi.us
Old Mar 10, 2005 | 11:40 PM
RacewayATV's Avatar
Default kazuma 150
GDiddy call me when you get the bike and I will help you out.
Kids ATV Raceway ATV
Old Mar 11, 2005 | 03:39 AM
kookis's Avatar
Default kazuma 150
In my opinion....there should be some play in the chain when the tensioners are pushed away from the chain. you don't want the chain taut when the bottom and top tensioner are squeezed toward each other and not in contact with the chain. If you can move the chain 3/4 of an inch upward when the tension is removed by squeezing the tensioners toward each other....it's probably ok. If the chain is too tight, It looks to me that it may rub on the plastic covering the swing arm frame behind the front sprocket teeth. My chain actually has a little "hill" in it where the tensioner is holding it up a little - hence acting as a "tensioner" so the chain doesn't have to be tense on its own. I recommend some lube on/in the center of tensioner gears where they rotate/spin - this is how i think it should be
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
