Advance degree timing key
I have a 03 Blaster and my buddy has a banshee. He bought a 4 degree timing key from vito's. He has since bought a new Ricky Stator and does not need the Key any more. I was wondering if it would work in my bike? They look pretty close.
I don't believe they are interchangable. However you can advance your timing by rotating your stator plate relative to the flywheel. All you need to do is slot the screw holes to make it adjustable, however be careful how far you do it because if you advance the timing too far you will cause serious damage to the engine. 4 degrees is the maximum the engine can handle, some banshees run up to 7 degree advance.
