Advance degree timing key
Old Mar 16, 2005 | 04:15 PM
skipzero's Avatar
Default Advance degree timing key
I have a 03 Blaster and my buddy has a banshee. He bought a 4 degree timing key from vito's. He has since bought a new Ricky Stator and does not need the Key any more. I was wondering if it would work in my bike? They look pretty close.
Old Mar 17, 2005 | 01:00 PM
Shav0's Avatar
I don't believe they are interchangable. However you can advance your timing by rotating your stator plate relative to the flywheel. All you need to do is slot the screw holes to make it adjustable, however be careful how far you do it because if you advance the timing too far you will cause serious damage to the engine. 4 degrees is the maximum the engine can handle, some banshees run up to 7 degree advance.
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
rcappie4
Jul 10, 2015 04:54 PM
D-Hagz
Jul 4, 2015 02:19 AM
