Need help! gas-cap leaking on 04 Blazer
Old Mar 17, 2005 | 09:36 AM
raptorACDC's Avatar
Default Need help! gas-cap leaking on 04 Blazer
My wife's Trail Blazer is leaking gas around the cap. Is it from a bad rubber gasket(it looks fine) or do these caps have problems? Thanks!
Old Mar 17, 2005 | 01:12 PM
BryceGTX's Avatar
Hello raptorACDC. No that is not normal. We have two Trailblazers and neither of them leak. No matter how much we bounce them around. When I get home, I will take at look at ours to see if I can see something that might be causeing your leak.
I hope this helps you
BryceGTX
Old Mar 17, 2005 | 07:57 PM
jayri's Avatar
Mine did it to but it was because I filled it to full, right up the filler neck within a quarter inch from the top.
Old Mar 18, 2005 | 11:10 AM
raptorACDC's Avatar
My 2000 TB leaked but it was a bad gasket. I thought it could be a cracked cap, but I can't see one.
Old Mar 18, 2005 | 01:18 PM
XtremeSkier's Avatar
i have a fuel gage cap on my scrammy, mine broke right away and gas leaked out everytime i road until i bought a new one. do u still have the stock black one? cuz it could be the gasket like raptorACDC said
Old Mar 18, 2005 | 08:23 PM
number4's Avatar
Hey,did you checked if the cap is cracked??Sometimes if you over tighten you'll accidentally crack the cap.Check it out and goodluck !!
Old Mar 18, 2005 | 10:28 PM
BryceGTX's Avatar
Hey raptorACDC. I checked my quad. Other than the gasket or a crack in the cap/sight glass like number4 mentioned, I can't imagine what else to check.
BryceGTX
Old Mar 19, 2005 | 10:34 AM
tbsleeper's Avatar
ur air hose that runs under the plastics is prob blocked i would check it thats why its leaking
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
