i need warrior help please
Old Sep 25, 2000 | 09:31 PM
streetracer's Avatar
Hi i have a 1996 yamaha warrior i was riding it the other day and it dies and i can't get it to start so i cleaned all of the electric connectors and check everything but it just won't start what could i do to get it to start and run fine please help
Old Sep 25, 2000 | 10:38 PM
99WarMachine's Avatar
Does the starter turn over? Is the battery fully charged? Make sure the spark plug isn't carbon fouled. I would also buy a Clymer's shop manual, and test the ignition coil and stator.
Old Sep 25, 2000 | 10:40 PM
speedy2's Avatar
put in a knew spark plug. then make sure all of the on off buttons are turned ON and not off. hope this helps
Old Sep 25, 2000 | 10:53 PM
yes the starter turns over it cranks fine i did put a new spark plug in what else could have happened
Old Sep 26, 2000 | 12:09 AM
Well, StreetRacer, the EXACT same thing happened to me. My quad is only a year old and it left me stranded one day. It turned out that my stator was bad. Not the large source coil, but a tiny little pickup coil. Yamaha will only sell an entire assembly for $300 dollars. What's funny about the Warrior's stator coil, is that it is submerged in the hot engine oil by design. I can't imagine such extreme heat is any good for electrical components. Anyways, you're obviously not getting a spark, but it turns over, so you know your switches are all good. You just changed the plug, so it's good, too. If the kill switch, neutral relay, starter relay, or solenoid was bad, it wouldn't turn over, so you can eliminate those. Providing that all of your wires are tight and secure, that leaves the ignition coil($50), stator($300), or CDI unit($300). Those are all Yamaha prices. But before you spend any money on ANY PARTS, buy a Clymer's manual at your dealer, or at WWW.CLYMER.COM. I bought mine for $30. Their latest manual only goes to 1995, but it's all the same. It has an excellent chapter on the electrical system, and has a trouble shooting-chart, with a ton of details to narrow down your problem. Also, you'll need to get a hold of an electrical multi-tester to perform the troubleshooting checks.
Old Sep 26, 2000 | 02:54 AM
Mr45auto's Avatar
The simplest method that doesnt cost a cent is to unscrew your spark plug, lay it on the cylinder where it will get a good ground and hit the electric start button. If it has a nice blue spark it's NOT electrical. If you have a spark then your problem is most likely fuel system related. Check for a plugged float valve on the carb, good fuel flow from the petcock, and a just plain dirty carb. If none of the above does you any good run a compression test.
Old Sep 26, 2000 | 03:19 AM
quaden's Avatar
You should start with the basics.
Spark, fuel, compression.
Which one dont you have?
If you do not know how to do these checks yourself, I would suggest you have a qualified tech do it.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
