Lightening Flywheel
Old Sep 25, 2000 | 10:36 PM
H300F's Avatar
I have heard lightening your flywheel will make hp. Is this something I can do myself and not spend any money on?
Can someone that knows alot about this explain what I have to do and how much I have to remove and how?? Thanks.
Old Sep 25, 2000 | 10:39 PM
H300F's Avatar
forgot to say it would be done on a 95 banshee
Old Sep 25, 2000 | 11:04 PM
Backcountry's Avatar
Lightening your flywheel involves machining material for the outer surface(and in some cases the face). This reduces the rotating mass that the engine has to turn, this is where the HP comes from. It's there it is just now freed up to be used as output at the wheels rather than used us spinning the rotating mass.
It requires chucking it up in a lathe and removing about .1" from the periphery. It's easy to do, and to do wrong. Most hop up shops will do it for around $60. It's mainly used in drag race and hill racer set-ups. The flywheel provides inertia to help the engine keep turning smoothly(not vibration wise) when you shift or get off the throttle and back on, the flywheel retains some energy as rotating mass. The effect you would see riding, is that if you let off the throttle and got back onto it, it will most likely require a slight squeeze of the clutch to get the RPM's back. It will however, rev faster(mainly no-load), due to it being lighter.
Old Sep 25, 2000 | 11:12 PM
H300F's Avatar
Hey thanks for the great reply. Here is my riding, trails, coal hill climbs , and sometimes i go to a track to ride for fun where there are jumps. i know a machinist and car engine rebuilder racing engines really well, and i am sure he has the machines to do this and would do it very cheap. think i should get it done, and is it hard to get off the quad and stuff?? can you explain it more so if i get it done i can explain to the man what exactely to do and what not to do.
thanks alot again,
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
