Removing Cover Over Radiator
Old Mar 22, 2005 | 09:10 PM
tk1469's Avatar
Default Removing Cover Over Radiator
I recently had to get at the top of my radiator on my SP500. In struggling with the cover, I broke off one of the tabs on the cover - now the $(@*$& thing rattles !! I'll probably break down and buy a new one, but is there anything that you can do to make those plastic covers come off easier without breaking ????
Any ideas or thoughts ???
Old Mar 22, 2005 | 09:15 PM
Bloombastic's Avatar
I don't know about how to take one off easier, but I would try to use some apoxy to put the tab back on before I'd shell out $$$ on new plastic. Its just going to be under the rack anyway and won't be seen.
Good Luck
Old Mar 22, 2005 | 10:19 PM
Metalfreakdude's Avatar
I took out the small screws the go into the pegs, drilled a bigger hole and screwed #10 x 1" panhead screws in there. That way the pegs have a solid shaft in the middle. Maybe your peg could be repaired this way. I have had mine off 100's of times. The rubber grommets do seem to loosen up after a while. I have experienced taking one off that had been on forever and I see how they could break easily. Maybe try a little vaseline on them?
Old Mar 22, 2005 | 11:55 PM
PolarisTheOnlyWayOut's Avatar
that is tha first i have heard of one breaking...i've takin mine off a tun of times an it seems to get easier...i would just put some kind of padding in their to avoid tha rattle and not buy a new one...i mean its under tha front rack and u kan't see it...imo
gorylewis
27
Oct 4, 2015 05:22 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 15, 2015 10:48 PM
cSchwartz
Jul 9, 2015 02:43 PM
