Fouled plug
Old Sep 26, 2000 | 05:49 PM
rottwolf's Avatar
What happens when a plug fouls exactly? Can it be used reliably after it fouls?
Thanks,
Jason
Old Sep 26, 2000 | 07:52 PM
hot_shoe_cv's Avatar
When a plug fouls, (mostly a 2 stroke problem)the result is that the center conductor and or the ground conductor becomes caked with a hard fuel/oil coating effectively blocking the spark. I have resurrected a few by spraying repeatedly with carb cleaner & brushing with a stiff brush, a somewhat labor intensive chore unsuited to the field, where plugs normally foul.
Altho I have never tried it but another trick that sometimes works with later model bikes with CD ignition is to ground the plug against the engine & turn the engine over several times. Sometimes the spark will burn off the fuel/oil crust from the insulator, allowing it to fire
Old Sep 26, 2000 | 08:07 PM
retro's Avatar
Check out my site, then go to NGK plugs. Most spark plug questions can be answered there.
ERIC
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
