800 EFI Suspension upgrade
Old Mar 30, 2005 | 03:14 AM
ImperiumDon's Avatar
Default 800 EFI Suspension upgrade
I am looking into replacing the rear springs on my Polaris 800 EFI. It feels very mushy and as soon as you get on the throttle, it sinks in the rear. Anyone have any ideas on upgrades for this problem. I'm also a pretty big guy at 270 lbs, but I notice the same problem on this machine with small riders as well. Please let me know your thoughts. Thanks.
Don
Old Mar 30, 2005 | 07:28 AM
jimmypsp700's Avatar
did you try adjusting the preload first?
Progressive makes fronts and possibley rears. Check HSP or Aaen.
Jim
Old Apr 3, 2005 | 02:58 PM
BAGGADONUTS's Avatar
my 2002 700 twin use to do the same thing when i got on the throttle and alls i did was adjust up the preloads, its working for now, ill most likely replace the springs with the ones that high lifter has out,
Old Apr 3, 2005 | 03:11 PM
spyder6's Avatar
how do you adjust the preload?
Old Apr 3, 2005 | 05:14 PM
tyler711's Avatar
You turn the ring-like things on the bottom of the spring. As your turn it, it has like steps on it, so each turn applies more pressure to the springs. Hard to explain, but if you look, you will see the adjusters on the bottom of the springs. There should be a tool in your toolkit that adjusts them, I think.
Old Apr 3, 2005 | 06:48 PM
LAMudMan's Avatar
I have just ordered HD springs for my 03 700 right from the polaris dealer. I hope that they are better than standard springs. Mine sags bad with no load on it. [img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Apr 4, 2005 | 09:40 PM
I cranked up the preload adjustment and it's a lot better now. I do, however, want to upgrade the shocks/springs. To be honest, and I'm not looking to take heat for saying this, I want it to ride more like the Rincon but a bit tighter. In other words, I want less marshmellow and more stability.
If anyone has any suggestions, it would be very helpful. Thanks.
Old Apr 5, 2005 | 03:19 AM
EPI sells HD springs.
Jim
Robinhood
Dec 26, 2015 10:28 AM
jankerstien
Sep 21, 2015 03:09 AM
bigred20653
Sep 19, 2015 02:11 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Brandon400
Sep 5, 2015 08:44 PM
