Where do I mount the solenoid on '05 Rubicon with 2.5 Warn winch
Old Mar 30, 2005 | 08:30 PM
cdr12's Avatar
Default Where do I mount the solenoid on '05 Rubicon with 2.5 Warn winch
I just bought an '05 Rubicon and can't figure out where to mount the solenoid. I got a bracket from CandS to mount the winch on the front but I can't find room to mount the rest. Anybody have any suggestions??? Any help would be greatly appreciated!!
Chris
Old Mar 30, 2005 | 09:23 PM
Gimpster's Avatar
I have mounted them in a few places. Inside the front fenderwell, but the cable colors have to be changed because the black and red are too short to go back to the battery from there. I simply swap the blue for the black and the yellow and red when I do it this way.
Another place I like to mount it is in the foreward area of the right rear fenderwell. The stator, speed sensor, carb heater etc.. connectors are clipped to the frame plate there. I will unplug them, move them to the backside of the plate and mount the solenoid on the outer side of the frame wire mounting plate, where the connectors were.( Probably the best spot ). and or in the same fenderwell only in the back, mount it to the side of the tool box, but use some bigger washere inside the toolbox to keep the bolts from pulling through if it is snagged by something the wheel kicks up.
----- Gimpster -----
95wolv
Sep 27, 2024 12:00 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
chewy78
Sep 8, 2015 10:37 AM
toonces
Sep 5, 2015 01:14 PM
