scrambler 500 clutch problems
Old Apr 2, 2005 | 09:38 PM
scamman72's Avatar
Default scrambler 500 clutch problems
i ordered a new clutch from rick ritter and a puller, when i tried to pull my old clutch off i would'nt budge. its like its froze to the crank any sugestions will be appreitiated. its the front clutch.
Old Apr 2, 2005 | 09:42 PM
ftwflh's Avatar
Put a hard piece of wood through your clutch and through the running board ,put the puller on and tighten,tighten and tighten it it will pop off after a while.
Old Apr 2, 2005 | 09:46 PM
SPORTSMAN70003's Avatar
The clutch is on there pretty good. It will take some effort to get it off. I usually use a hammer handle and wedge it in the clutch to keep it from turning and then tighen the puller pretty good and it should pop off but it will take a little grunt.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
