lt80 sprocket change
Old Apr 4, 2005 | 11:42 PM
Cougar205's Avatar
Default lt80 sprocket change
Well I'm tired of fixing the 428 chain ,sprockets,and tensoner.I'm going back to the stock chain and gearing.If I replace the front sprocket
with an 11 tooth do I need to lengthen the chain?Thanks Al:
Old Apr 5, 2005 | 04:40 AM
Quad4Fun's Avatar
Hey there,
That stinks. I've heard numerous people say that size chain works great.
What size sprockets and what kind (aluminum/Steel) are you using?
Is there a reason you are having problems, that you know of?
Anybody else have any ideas??
The reason I ask is that I'm also looking at going with new gearing and going with #40 chain and a 13 to 15 front and 26 rear. You can get half links for that chain, which makes sizing it easier.
Anyway, good luck [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 5, 2005 | 06:48 PM
duneaholic's Avatar
I didn't have any luck with the 40# chain. The half links kept breaking. The chain stretches real fast too. Just make you a roller and tension it that way. I've since gone with a good quality 428 chain and it didn't stretch near as fast as the 40 did. You may have to make a couple of different holes for the chain stretching. I drilled a hole thru the steel plate that that the chain runs by and put in a chain roller to keep it tensioned works good.
If you are talking about the mid-west mini chain tensioner I know what you are talking about. I think it is a really poor design.
Old Apr 5, 2005 | 11:07 PM
BdBanshee's Avatar
I just tried to put the 11 tooth front on yesterday, no luck without either a longer than stock chain, or maybe putting on a 21 tooth rear at the same time.
bigbear350quad
Sep 11, 2015 12:40 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
