dyno
Old Apr 6, 2005 | 07:01 PM
hyflyer's Avatar
Default dyno
alright, i finally put my ds on the dyno. full stage II kit. the tm45 does not have the accelerator pump activated and it has a dyno jet kit. the hp was 48.39 and the tq was 39.86. i live in kansas and i have a 145 main in the carb with a carb mount filter. i was expecting more like 55hp. the guy running the dyno said that the exhaust sniffer said that it was way fat. it did not want to pull past 7000 rpm. it did but not with any power. i called ron wood and he said for my altitude and temp i should be running a 147.5 jet with a stage II. he also said that i should be around 55 hp and should pull strong to 9000 rpm. do i have to activate the accelerator pump to get the hp that i am looking for and should i go back the the k&n in the airbox. is that dynojet hurting my performance. my intake was also ported by sandcrazy 10. his intake is a lot more ported than the woods. please help
Old Apr 6, 2005 | 07:15 PM
crazypainter's Avatar
Default dyno
what tires and gearing are you running? It all makes a difference. I've seen other bikes with more mods that didn't make much more power than yours. Don't sweat it, all dynos are different, they're good for comparisons for before and after on mods, which will tell how much you've really gained. Use it as a tool for jetting and don't put too much emphasis on the peak numbers.
Old Apr 6, 2005 | 07:19 PM
shmee's Avatar
Default dyno
AMEN!!!!
Old Apr 6, 2005 | 07:27 PM
H's Avatar
H
Default dyno
I saw a bike with some HPR goodies on it that was supposed to be about a 58-60 HP kit. It dynoed much lower. This dyno just wasn't as forgiving. Not saying it didn't have the ponys, saying that dyno didn't show it with the tires and gears
Old Apr 7, 2005 | 04:55 AM
thebigshow's Avatar
Default dyno
hyflyer, u would proberly would grab a couple more ponys if u would run your snorkel tube instead of just a carb mounted filter...
Old Apr 7, 2005 | 09:47 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Default dyno
I've seen on the dyno that running fat can lose as much as 5 to 6 hp. That would put you in the hp range you expect.
On the intake, sometimes MORE ported is not better!!
The carb mounted filter needs less jet than a carb running the snorkel.
Old Apr 7, 2005 | 08:02 PM
hyflyer's Avatar
Default dyno
thanx for the info guys. i have an aluminum airbox. i heard the 2004 intake tube is better. what else do i need to order. i do not have anything. thanks again
Old Apr 7, 2005 | 08:08 PM
shmee's Avatar
Default dyno
where in kansas do you live?? what part of state?
Old Apr 7, 2005 | 08:09 PM
hyflyer's Avatar
Default dyno
wellington, just south of wichita
Old Apr 7, 2005 | 08:13 PM
shmee's Avatar
Default dyno
you should come to nebraska for the races in a month!
