Shimming Needles
Old Apr 13, 2005 | 06:17 PM
beetlegus's Avatar
Default Shimming Needles
Can someone tell what the purpose of shimming your carb needles is? What benefit does this provide? I just installed a new Muzzy exhaust on my KFX 700. Should I shim the needles when i jet it? Thanks
Old Apr 13, 2005 | 07:10 PM
sammydogs64's Avatar
The purpose of the shims is to correct a low end(just off idle) stumble of the prairies. If you are at a standstill and you jam full throttle, if you feel just a quick hesitation or burble you should add the shims. I put in .030" shims with a stock pipe and I backed off my air screws 1/4 turn. Mine runs perfect like that at the moment, I hope it stays this way when the hot weather gets here.
speedbuff
13
Nov 11, 2020 10:16 AM
Dammar
Apr 20, 2016 06:03 AM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
