Verticle vs Horizontal
Old Apr 13, 2005 | 11:09 PM
mahnster's Avatar
Default Verticle vs Horizontal
Heres the dilemma I am in ... I am fixing to put a motor in a trike or a bike frame. The frame wont be the problem. I have a motor but the only problem is that it is a verticle shaft. I would need a horizontal shaft for it to work correctly. Is there a way to make it work or do i have to find a different motor? Thanks
Old Apr 13, 2005 | 11:16 PM
sblt500r's Avatar
use a gear box out of a tractor. some have a pulley on the bottom and a sprocket on the side to run a chain from. or get a tractor rear end with the pulley on top.
Old Apr 19, 2005 | 05:38 PM
mahnster's Avatar
Alright thanks for the idea. I think just finding a horizontal shaft motor will be easier in the long run.
Old Apr 19, 2005 | 09:45 PM
sblt500r's Avatar
yup use a horzontal put a clutch on it and a chain to a solid axle with a sprocket and away you go. no worring about the belt and crap. i did all that before with a vertical engine much easier with a horizontal. good luck with it.
Old Apr 20, 2005 | 01:57 PM
TexasPsycho's Avatar
Horizontal is about the best way to go. If you use the vertical your just about going to have to use some sort of gear box. You can find some in Northern catalog or on the internet but it's just going to be more $$.
partychief
ATC 3-Wheelers
Nov 10, 2008 10:44 PM
Toolboy
Feb 13, 2007 12:06 AM
swivel
Jul 11, 2002 01:11 PM
JIGA
Oct 7, 2000 12:02 PM
